Can you change the Shape Profile or Angle in an existing component...one where the settings have been "Applied" AND the Create Shape menu has been "Closed"? Once I "Close" the Shape Menu, and re-select the same component it creates a new component when I open the Shape Menu. I know you can change it before you "Close" the Create Shape" when first creating it.
I know I can change the other properties but can't seem to change the shape or angle which is only available in the Create Shape menu and can't be modified once you "Close" the Create Shape menu.
Changes in Create Shape Menu
Re: Changes in Create Shape Menu
See this thread from a couple of days ago on the same subject - viewtopic.php?f=27&t=38274
Adrian,
Thanks for the reference. I am new to the forum and gave up after doing a "brief" search of the subject before I posted.
Regards,
George
Regards,
George
