printNC posprocessor
- revwarguy
- Model of CNC Machine: homebuilt
Is there a post processor for the printNC machine? I know one exists in other software for it. If not, how do I go about creating one?
Re: printNC posprocessor
It's the controller that it uses that is more important than the machine itself when it comes to the post processor. From what I can see most people build those machines GRBL based for which post processors already exist.
- revwarguy
From what I've seen from their Discord server, it appears that most use LinuxCNC instead of GRBL, but I am thinking of using the Centroid Acorn board. So I just start with the appropriate one for those and see what happens?
Yes, whichever controller/software you use is where you should start with the post processor.
- gio14
- Model of CNC Machine: roland modela 540
With LinuxCNC I use the post processor EMC2
- revwarguy
Thanks, Gio. Did you have to make any modifications to it?
Hi good day. I may be in the wrong place but I hope someone could help. I have a CNC machine from china with 4th axis along the Y axis. I am looking for a post processor I can use with this machine. I also have a RichAuto A18 Controller. Can anyone recommend one or more I can use or send one.
