I am having a problem when working with a 3d project. During the initial design the 3d view is interactive as when I make a change in the drawing it shows on the 3d view and makes it easy to see what your changes are doing. It seems now that when I decide to run a sample tool path and preview it that when I go back to make changes that the changes do not show up in the 3d view. I have tried to get the 3d interactive view back but have failed..
Any Help??
interactive 3d view
- FixitMike
Re: interactive 3d view
Did you Recalculate All Toolpaths after making the changes?
Yes, I did both of those. The only way I can see my changes is to recalculate and run preview again after refreshing the preview each time.
ahaaa,,, I was not closing the preview pane when I went back to the drawing. I was resetting it but not closing it. This may have solved my problem..... This seems like a set that shouldn't have to be taken, but oh well.
Thanks much
Thanks much
- adze_cnc
...and those who have a need to keep the preview open would get irritatated that it always closes. Pretty much a no win situation.
