Vectric InLay
Aussie
Model of CNC Machine: Robotics Model 8
Vectric InLay
Post by Aussie »
I am inlaying acrylic into wood and seek your advice for the best method of bonding the acrylic to the wood.... I am thinking strong thin double sided tape.
Appreciate your recommendations.
Ron
Crafers Crafts
Aussie
Re: Vectric InLay
Post by Aussie »
Aussie wrote:
Sun Jul 25, 2021 7:31 am
Here is my test
Ron
Crafers Crafts
Re: Vectric InLay
Post by martin54 »
Working as a signmaker I use a number of double sided tapes & films, as long as everything is cleaned properly then there shouldn't be any trouble bonding the 2 materials. You can also use certain adhesives. I use a range by a Company here in the UK who are very helpful. If I have 2 substrates that need to be bonded & not sure what to use I phone their technical department for help. Probably a Company you could use & do the same :lol: :lol:
These 2 jobs were done dofferent ways, the house sign was done using an adhesive & the path names were done using double sided tape, both jobs are external & were done some time ago now.
Aussie
Re: Vectric InLay
Post by Aussie »
Thank you Martin
As the inlay will be in a tray and not subjected to the elements or rough handling, I shall use the tape method,
Appreciate your advice as always.
Regards,
Ron
Crafers Crafts
