Missing Toolpath List in Preview
- SteveNelson46
Has the show toolpath list in the preview screen been removed in V11? I turned it on in v10.5 but I can't find it in V11. Well, to be honest I can't find it in v10.5 again either.
Re: Missing Toolpath List in Preview
Do you mean the toolpath operations? That's a toggle in Options on the edit menu.
If you mean the actual list of toolpaths than that's there for me. Have you setup multiple sheets? By default you will only see the toolpaths for the active sheet so you may need to switch to the All Sheets view or the other sheets.
- SteveNelson46
- dealguy11
Try making Aspire full screen, or increasing the window height.
Steve Godding
- SteveNelson46
Thanks Steve. Your solution didn't work as I was already at max screen size. I'm using a 65" monitor set at 300 % magnification (recommended by the manufacturer). So I tried playing with the custom magnification settings. I set it to 275% and that worked so I started increasing it a little at a time. After a few tries I just reset it back to the recommend setting and everything still worked. Go figure. I thought that when I migrated to V11 the setting had been turned off. Apparently, there is no setting. What's weird is V10.5 still works fine and always did. Must have been something with internal scaling in the program.
