I am making a box for a small solar collector for my weather station.
I have the box done.
I was going to make a conservative utilitarian cover - BUT - WHY?
So I decided to make a fancy roof cover.
I am having a bit of trouble.
I got the shape I want - but there is a protrusion on the top that I do not want.
See attached file
https://www.dropbox.com/s/iparkblwysag1 ... crv3d?dl=0
I have not finished this - so if there is feed and speed of other dumb stuff I will get that.
I just need help on the protrusion.
Protrusion issue on roof
- Leo
- SteveNelson46
Re: Protrusion issue on roof
Something like this? Make the inside rectangle really, really, really small. I used .0001 for the width.
- Solar Roof.crv3d
- (1.74 MiB) Downloaded 45 times
- Leo
You used EXTRUDE?
- SteveNelson46
Nah! Just a 2-rail sweep. You'll have to zoom in really close to see the inside rectangle.
- Leo
Steve,
There is something a bit off about your model. It comes to a peak whereas all four corners meet in the middle. Like as if you created a SQUARE - then resized it.
What I am trying to get is the front and back to be longer than the sides. In that, there would be a straight line on the top of the roof. If I sand off the protrusion - that is what I would get.
So - your design IS really close.
- SteveNelson46
I really didn't understand what you wanted. I'll have to work on it later. I have a dentist appointment in a couple of hours.
- dealguy11
If you make the inside rectangle long (1.75" x .005") then you'll get the shape you want.
Steve Godding
- Leo
Yep - I got it
Thanks all
Thanks all
