Am I correct in saying that you can not edit or change a "shape" once you have accepted the create shape from vectors.
While you can use the "wrench" to change shape and base height you can not change an angle etc.
The component must be deleted and created again.
Ron
Edit Modeling Tool
- Aussie
- Model of CNC Machine: Robotics Model 8
Edit Modeling Tool
Ron
Crafers Crafts
Crafers Crafts
- dealguy11
Re: Edit Modeling Tool
What changes are you thinking of? Once a component is created, regardless of what tool you use to create it, it's just a component. You can mess with the tilt, fade and height just like any other component. You can also distort it and use the modeling tools, use vectors to cut them, and to clear areas inside and out.
Steve Godding
