Using RARzip files in Aspire
I've downloaded a couple of RARzip files from Design and Make and I have unzipped them but I can't put them into Aspire to carve them. I opened them as an STL file. There were other options. Should I have used one of the other options?
- dealguy11
Re: Using RARzip files in Aspire
RARZip is just a compression scheme. You will need first to unzip them. If they are stl files you will need to import them into an open project.
It would probably have been easier to download them as v3m files.
Steve Godding
You are better off downloading as V3M files as dealguy11 has said, main advantage of that is that you will be able to add them to your clipart folders within Aspire & you can view them as thumbnails the same way you can view any of the included clipart files.
As a RAR file you will need to extract them before you can use them, once extracted if it is one of the projects or hack of the week file then once it has been extracted you can install it the same way you would with any software & it will instal in the correct folder, if it's just a single individual file then I tend to just put them in the appropriate clipart folder within the software, ie if its a flower then I would put it in the Plants & Fruit folder
