Technique that I saw..Trying to figure out.
tnwalkinghorse
Model of CNC Machine: Pre-sale
Post by tnwalkinghorse »
Does anyone know how to achieve this look with Aspire? It looks like flutes running parallel to each other with text over layed on top with a V-bit. Thanks!
Re: Technique that I saw..Trying to figure out.
Post by adze_cnc »
If you look at the "M" there appears to be artefacts of a raster 3D finishing toolpath. So, model the "corrugation" and the text as 3D components?
The corrugation probably with a two-rail sweeps. The text as an "extrusion" with tapered sides (however that is accomplished in Aspire).
SteveNelson46
Post by SteveNelson46 »
Easy to do in Aspire. Create your own unique bit for the background and then use the toolpath preview to create a component. Add a text component(s) on top and create a finish toolpath for all.
This is pretty crude but illustrates the technique. The file is too big to upload so here is a link.
https://drive.google.com/file/d/1kZ2omY ... sp=sharing
Since it is a raster cut it might take a while to carve.
