Belly Cut on an electric guitar
This has been discussed many times but i have not been able to figure out how to get it done.
this is all i need to figure out before making my very first custom guitar.
Re: Belly Cut on an electric guitar
Can you post a photo of what you want to do, and where you run into trouble in Aspire?
Do you have some sample links to forum posts where this has been discussed?
Seems fairly simple to me:
- model the belly cut-away
- make a 3D Roughing toolpath (optional)
- make a 3D Finish toolpath
This is what i have so far.
i did a search for belly cut in the search forums area... and read through those. confused is all i came out with
where i am having trouble is modeling the cut
the tool paths are easy to deal with
It looks like you could take what you have and use the sculpting tool to smooth the transition.
As is usual with Vectric products, there are at least 3 different ways to approach the problem. Besides what is shown below, this could also be done using the fluting toolpath, or the moulding toolpath.
I started with an outline of the instrument body shape. I created a 3D component of the desired thickness using Create Shape from vector outlines Next I selected the shallow dome/dish clip art I set the dish component with a base height and the dish depth
Next I baked the two components together
Then I used the sculpting tool to smooth the edges.
This is the quick-and-dirty outcome. More sculpting would yield better results.
that works,
i will give it a try.
Thank you
Thank you
That will work fine,
a little hand shaping once it is cut but thats ok, i will keep messing with it until i have it right!!
Thank you all for the help
- Jim_in_PA
- Model of CNC Machine: Camaster Stinger II SR-44 (MacOS user)
I use the molding tool path for this operation on my guitar bodies.
