Modeling tab Separating from Group tabs
- Model of CNC Machine: 5X10 Industrial Cnc
Having problems with my modeling tab, not sure if im switching something on, for some reason my modeling tab opens up separately than my grouped tabs, Original tabs on the bottom (Drawing tab, modeling tab , clipart tab, and layer tab) now the modeling tab is gone and opens up separate from the group. I tried inserting a screen shot, no luck.
Re: Modeling tab Separating from Group tabs
Drag it back over to the others and it will auto dock back in place.
that worked thanks, now how do I get the drawing tab to hide and when activated scales down the drawing
Click the pin in the top right to activate auto hide. Depending on your settings you may need to go into the Options on the Edit menu to set the Window Layout save options to Yes to preserve your changes.
