Removing Gadgets
- gkas
Removing Gadgets
I opened the folder "C:\ProgramData\Vectric\Aspire\V10.5" with Open Application Data Folder. I have more gadgets than are in either the "V10.0/Gadgets" or "V10.5/Gadgets". Where else are they stored?
Re: Removing Gadgets
Might be:
Code: Select all
C:\Users\Public\Documents\Vectric Files\Gadgets
- gkas
You are correct. That's it. I wonder why the different storage location than "Application Data Folder"?adze_cnc wrote: ↑Fri Apr 23, 2021 2:25 amMight be:
Code: Select all
The ProgramData area is for gadgets that come with the software like the Keyhole Toolpath and Job Sheet. The Vectric Files area is for 3rd party and optional gadgets. Things like backgrounds, clipart, tutorials etc are also stored in the Vectric Files area.
Items in the ProgramData area can be overwritten during upgrades etc.
- gkas
OK. That sounds reasonable.Adrian wrote: ↑Fri Apr 23, 2021 8:25 amThe ProgramData area is for gadgets that come with the software like the Keyhole Toolpath and Job Sheet. The Vectric Files area is for 3rd party and optional gadgets. Things like backgrounds, clipart, tutorials etc are also stored in the Vectric Files area.
thanks
- gkas
thanks
