Here is what I come up with based on two different Amana bits. I'm a few thousands off your calculation.
Cutting Boards with Inlays
Re: Cutting Boards with Inlays
Gary Mitchell
Kentucky, USA
Kentucky, USA
- Aussie
- Model of CNC Machine: Robotics Model 8
Hi Gary,
I use Broinwood method.
If you don’t mind spending a few dollars check out his video on the website, after a day of experimenting I am now getting the results that I wanted.
Regards
Ron
Regards
Ron
Ron
Crafers Crafts
Crafers Crafts
Gary:
"When in doubt draw it out" might be the catchy way of describing how I did things. In Rhino 3D I drew a cricle. Then a vertical line. I rotated the line to the 6.2 degrees. I then moved the line using the tip as the starting point until it intersected with the circle at the tangent. I drew a horizontal line at the bottom of the circle. I extended the sloped line to the horizontal line. I mirrored the sloped line to the other side of the circle. I then measured between the end points of the two sloped lines where they cross the horizontal line.
Attached are two .crv files (one for each bit mentioned in your images) that contain the curves imported from Rhino. The theoretical flat for your .5mm bit is 0.4486mm.
Steven
Steven
For calculating the theoretical flat of a tapered rounded end bit?
This was extremely helpful. Thank you very much for taking the time to prepare these files.
Gary
Gary Mitchell
Kentucky, USA
Kentucky, USA
