Advice Needed
- Model of CNC Machine: Router engraver 50 X 40
Advice Needed
I am a novice (eighty two young) CNC Router user and I recently Bought a K40 Laser engraver ,will some kind member advise me ------ Which software can I use with Mach3 as cut2D doesnt work on this machine. Please help Joe.
Re: Advice Needed
Your laser should of come with it's own software to run the machine, not Mach 3. Usually you'll need to import either a Bitmap, dxf or ai file, etc., rather than toolpaths created with the Vectric software. You might want to google the K40 Laser and watch some of the videos.
Gary
Gary
- Leo
Re: Advice Needed
I use Vectric for most of the work then DXF out then DXF into other software. Which I run my laser direct from.
www.leosworkshop.com
