cut out time in aspire
- Model of CNC Machine: Probotix Meteor
Hi: I have a question. I made a simple sign. Using only 2 bits. The engraving time was 34:44 min, cut out time was 5min. My problem is the engraving took 2 hours to do. What am I doing wrong? Help? Thank Ron
- TReischl
Re: cut out time in aspire
Would help if you showed us what you are doing.
Feedrates? Depth of cut per pass? A lot of detail? Could be anything. Or, if everything is set correctly that is how long it takes. I often do jobs that require over 10 hours of cutting time.
If it will make you feel better, ask yourself how long it would take you to do it by hand and what would it look like when you were done?
Ooops, misread a bit there. Sorry. You need to adjust your scale factor for the time estimate.
- Model of CNC Machine: Camaster Stinger II
You have to adjust time factor in your software to get a more accurate measurement of time to cut.
If you open the Icon for time on the right side (looks like a clock) there is a number that can be edited by the user. This is a quality factor that you can use to adjust Aspires machining time calculation.
You know what the sytem told you machine time was suposed to be and you know how long it actually took
Divide the time it actualltook by the time the system told you it would take and enter that number into the editable field.
34.55 + 5 = aprox 40 min
2 hrs = 120min
120/40 = 3
use 3 a a quality factor
You can change this over time when you have more data to draw on - it will never be exact because of many variables but you can get within 10% regualarly
2 hrs = 120min
120/40 = 3
