This is probably one for Adrian.
Just tried the Dado tool creator and I get an error (lau Line:173) i’m running Aspire 10.019
Any Ideas ?
Paul
Dado Tool Creator
- Model of CNC Machine: Shopbot PRS Alpha 120-60
Re: Dado Tool Creator
Are you using the latest version? I would expect that error if you were using a version made before v10 with a v10 version of Aspire/VCarve/Cut2D.
The latest version is here - http://gadgets.vectric.com/V10/dado_creator.html
Adrian,
Yes, that the one I downloaded
Is this the error you're seeing?
If so that's definitely a wrong version issue. The handling of the tool database picker changed from v9 to v10 so the only difference between the two is line 173.
In the v9 version it's:
and in v10 it's:
Code: Select all
dialog:AddToolPicker("ToolChooseButton", "ToolNameLabel", g_default_tool_name)
Code: Select all
dialog:AddToolPicker("ToolChooseButton", "ToolNameLabel", g_default_tool_id)
Yes, that is the error, can I edit that line ?
Yes but you shouldn't need to. I double checked the version that I linked to in my first reply and it is the correct version. Might be worth re-downloading and re-installing it.
Adrian,
I re-downloaded and installed the gadget and it is working fine.
Many thanks
Paul
Many thanks
Paul
