Has anyone installed Paul Rowntree Spiral gadget in Aspire V10, I have installed it but I get an error
Thank you
Paul
Treesoft Spiral
- Model of CNC Machine: Shopbot PRS Alpha 120-60
Re: Treesoft Spiral
There were some changes to the way gadgets work in v10 which has affected some of Pauls gadgets. See here for details - viewtopic.php?p=239252#p239252
There is a spiral gadget on the main site that may or may not do what you want but works in v10 - http://gadgets.vectric.com/V10/spiral.html
Re: Treesoft Spiral
Adrian, thank you
The spiral gadget does not work for my purpose, which is cutting circular pockets, the one on the main site does not cut
the same way.
I might have to use an older version and create some spiral vectors for a specific pocket sized and copy the vector to V10
Paul
the same way.
Paul
Re: Treesoft Spiral
Might be worth trying with just the standard vectors and toolpaths. There were changes to the cutting strategy for pockets in v10 so whatever behaviour you didn't like in previous versions may have been changed now.
