question on raised letters
Al Allison
Model of CNC Machine: Shop Sabre 4896
Post by Al Allison »
Can someone please direct me to a tutorial or good example of making 'raised' letters. Not exactly a prism, but where the letters are up, possibly flat on the top, but with a bit of a rollover edge and the background is down flat. Say a 12" high "W" with a serif, about 1/2" thick letters. Something fairly efficient with all the material removal this requires. Thanks for the help.
Re: question on raised letters
Post by Rcnewcomb »
There are several solutions depending on what you want for the appearance.
V-Carve with an outer box and a flat depth.
Profile On the line with a V-bit or roundover bit, and then optionally Profile On the line with an end mill.
There are probably a few other methods.
10 fingers in, 10 fingers out
another good day in the shop
Al Allison
Thank you Mr. Newcomb. I will try your methods.
