2d view colors
kyeakel
Model of CNC Machine: Camaster Stinger I, Shopbot PRT 9648
2d view colors
Post by kyeakel »
Is it possible to change the colors of the 2d view screen? I'd like to have black screen, bright green drawings, yellow grid dots, blue guidelines. I find it very hard to see the grid dots. An option to change the dots to graph paper would also be nice.
Kipp
CAMaster Stinger 1
Shopbot PRT 9648
Aspire 8
Cut2d,Cut2dLaser
Re: 2d view colors
Post by highpockets »
Not sure, check under menu option Edit->Options.
kyeakel
Re: 2d view colors
Post by kyeakel »
All i see is changing upper and lower ruler colors. How does one display the lower ruler?
CAMaster Stinger 1
Shopbot PRT 9648
Aspire 8
Cut2d,Cut2dLaser
Re: 2d view colors
kyeakel wrote:All i see is changing upper and lower ruler colors. How does one display the lower ruler?
In a two sided job the ruler colours change so you can see which side you are on.
Re: 2d view colors
Post by Rcnewcomb »
Kipp,
Windows 10 does have a Dark Theme, but that is not currently inherited by Aspire.
You can send your feature request to support@vectric.com.
The forum is mostly end-users, although team Vectric does drop in from time to time.
For those who wish to know how to activate the Dark theme in Windows 10:
To enable Dark Mode, head to Settings > Personalization > Colors. Scroll down and select the “Dark” option under the “Choose your app mode” section.
10 fingers in, 10 fingers out
another good day in the shop
Beans2toot
Model of CNC Machine: Axiom AR8 Pro+
Re: 2d view colors
Post by Beans2toot »
Good question Kipp and thanks to all the replies to the question.
I am colorblind and tha "Dark" feature would really help.
Gordon
