Aligning Single Clipart to Curve
- Mark's Wood Chips
- Model of CNC Machine: ShopSabre 23 with Rotary
I know that you can use "Copy Along Vectors" to place multiple copies of an object along a curve but instead, I want to take a single elongated object and form it to the shape of the curve (see attached picture - want weave to take the shape of the curve). I've been using distort object to accomplish the task but I would like to know if there is a more automated way to accomplish the task?
Mark
Mark
- ohiolyons
Re: Aligning Single Clipart to Curve
You should look at Extrude and Weave.
Create your weave first and then extrude that along your vector.
John Lyons
CNC in Kettering, Ohio
- Mark's Wood Chips
I don't want 3D, instead a V-carved design.
- highpockets
- Mark's Wood Chips
Yes, that is the way I have been doing it. I'm looking for an automated method similar to text on a curve.highpockets wrote:Have you tried Distort Selected Object?
Mark
- Mark's Wood Chips
Sorry, I don't have a file. This is an academic question only.ohiolyons wrote:could you post your file?
Mark
- ohiolyons
He said he was using Distort Objects.
Not certain how much automated you could want. Explain please?
You select the clipart, then a vector and press apply and it is distorted.
I guess the answer to your original question is No.
John Lyons
- highpockets
Whoops!!!Mark's Wood Chips wrote:Yes, that is the way I have been doing it. I'm looking for an automated method similar to text on a curve.highpockets wrote:Have you tried Distort Selected Object?
Mark
- Mark's Wood Chips
That's my conclusion as well.ohiolyons wrote: I guess the answer to your original question is No.
- Mark's Wood Chips
The practical application to my question was designing a smooth flowing V-Carve on a gently curved walking stick. The weave pattern stick has the series of weaves stacked end to end. Each individual weave pattern is straight, I wanted it to follow more closely to the actual curve of the stick. It's acceptable the way it turned out but I was hoping to soak up some greater wisdom from my friends on this forum .
Mark
Mark
- Model of CNC Machine: Shark Pro Plus
Did you use the Distort Object function Between Two Vectors? Here are a couple of pictures of distorting a weave pattern between two vectors.
- Mark's Wood Chips
No, I haven't tried that - thanks for the suggestion.
Mark
Mark
I'm confused now. Using the Distort Objects was suggested earlier in the thread and you said you were already doing it that way.
- Model of CNC Machine: Camaster Stinger SR24
Im not smart enough to solve your dilemma, but those are some sweet looking walking sticks!
Joe
I have a chip on my shoulder....several more in my hair and lots more all over my shop floor.
