split array
lavon
Model of CNC Machine: cncrouterparts
split array
Post by lavon »
I have a 4 image array. How do I split out only ONE of the copies and make it a completely different job to save, open and edit in Aspire10?
thanks
ohiolyons
Model of CNC Machine: Laguna IQ HHC, 3HP
Re: split array
Post by ohiolyons »
Not entirely certain what you are trying to do.
If you only want to cut 1 then select it and create toolpaths.
In the same file you can select all of them and create separate toolpaths.
Be careful of your center when cutting only one. It will be the same as the 4 model version unless you change it.
You can also select one, copy it, and create a new file and paste it in.
CNC in Kettering, Ohio
lavon
Re: split array
Post by lavon »
"You can also select one, copy it, and create a new file and paste it in."
thank you OHIOLYONS
