Not everyone uses Chrome hence why the reference was causing confusion. I use Edge, Opera and Firefox. The other poster was using Firefox.
Printed Manual
Re: Printed Manual
Re: Printed Manual
The new Help pages are frame based and most browsers don't support printing the entire contents of a frame natively. It was possible until recently to use the context menu to open a frame in a new tab but Google removed that option from Chrome (and all Chromium based browsers) but you can get the functionality back by installing an extension.
A workaround that doesn't involve installing extensions is to drag select the text at the top of the Single Page frame and then press Ctrl-Shift-End to continue the selection to the bottom of all the pages in one go. Now when you print (or use the Windows Save as PDF) option it will print/save the entire selection rather than just the visible frame.
Re: Printed Manual
I guess Firefox doesn't have the 3 dots. Bummer.....
Don
Diamond Lake Custom Woodworks, LLC
http://www.dlwoodworks.com
- TReischl
Re: Printed Manual
Manual? I do not need no stinking manual!!!! Heck, I cannot even read, so I would need one with pictographs.
Re: Printed Manual
Hi All,
Just an FYI that we've updated the manuals which should mean that they are printable in one go now. It takes an age to preview the print on my PC but it does eventually get there
Cheers,
Adam
Cheers,
Adam
Re: Printed Manual
Seems to be working now on everything I've tried except for Opera.
- ohiolyons
Re: Printed Manual
FYI make sure you have background graphics option on.
John Lyons
CNC in Kettering, Ohio
