I know this has nothing to do with Aspire but I am going to throw this out there. I own a Laguna SmartShop 2 and I am interested in buying a laser attachment for it. Does anyone know if this is possible for this machine and if so what supplier to contact?
Chris
Laser Attachment on a CNC Router
- Jim_in_PA
- Model of CNC Machine: Camaster Stinger II SR-44 (MacOS user)
Re: Laser Attachment on a CNC Router
I can't help you with your specific question relative to your machine and compatible lasers, but do keep in mind that add-on lasers for CNC machines are pretty much limited to "engraving" type work due to power and unlike a dedicated laser, you need to figure out how you're going to properly ventilate the nasty fumes created when they are burning the material you are processing. It's important.
- TReischl
Just thought I would remind folks who have lasers:
"Thou shalt NOT burn PVC or attempt to cut galvanized metals"
EXTREMELY dangerous.
Poly Vinyl Chloride: produces hydrochloric gas when burned. Will kill you dead in a matter of minutes.
Here is a link with a bunch of other stuff that is bad to be cutting with a laser:
https://www.troteclaser.com/en-us/knowl ... rocessing/
- highpockets
