aspire 4.5
4x4laguna
Model of CNC Machine: 4x4 Laguna
aspire 4.5
Post by 4x4laguna »
I got a job that was made in Aspire 4.5. I have 8.5.
I can not seen to open it. can someone help?
Re: aspire 4.5
Post by Rcnewcomb »
What is the error? You should be able to open earlier version.
10 fingers in, 10 fingers out
another good day in the shop
sylvan356
Model of CNC Machine: CAMaster Stinger 1 w/Rotary, Aspire 10.5
Re: aspire 4.5
Post by sylvan356 »
More likely than not the file you received was created in a pirated copy of 4.5. Legitimate copies of the software will not open them. They can only be opened with the pirated copy!
Savannahdan
Re: aspire 4.5
Post by Savannahdan »
Another thought could be what I call mismatched toolbases. The 4.5 version file could be looking for a tool you don't have in your 8.5 toolbase. Not sure if that is still an issue since I haven't run into it in quite some time. Also, not sure how you resolved it if that's the issue other than contacting Vectric Support.
