Select all /except/ holes?
- Model of CNC Machine: 2006 ShopBot PRT96 Alpha
I'm working on a project that involves 400+ little 3" hex tiles with six holes in each tile.
The tile holes are all drills and the tiles themselves are outside profile cuts.
I can easily select the holes in all 400 nested tiles by using the selection tool to grab only the holes.
The problem comes when I need to select everything else that's NOT a hole.
Is there some sneaky trick I can use in order to avoid having to individually select all 400 tiles?
I'm using Aspire v9.5
Thanks folks!
g.
Thanks folks!
g.
Proud owner of F-15C 80-0007
http://www.f15sim.com - The only one of its kind.
- IslaWW
Re: Select all /except/ holes?
Put the holes on a separate layer from the hex geometry's
Gary Campbell
GCnC Control
GCnC411 (at) gmail.com
GCnC Control
- Model of CNC Machine: Stinger 1 and Mabel, both with 4 axis
The method Gary suggested is the best way to approach intricate designs. The sneaky trick that is the second best way is to select all the holes and then box select every vector while holding the shift key down. That way everything that was previously selected will be de-selected and everything that was not selected will become selected.
Euan
Euan
Select all the holes first, then hit G to make them a Group. Now CTRL-A select all. Shift select the grouped holes and all that is left selected is everything but the holes.
4D
4D
Lots of different ways as you can see but I would use Garys mehod of using different layers. Get use to using layers for designs as you build them, using them properly will probably make most things that you do easier & quicker. It's not just when it comes to selecting vectors either
I've tried using layers, but I'm starting from a DXF file. I'll try the other suggestions tomorrow and let you folks know how it worked out.
Thank you!
g.
Thank you!
g.
Definitely layers. Use the vector selector (as you have done) to select the circles. Right click and choose to move those circles to a new layer. Everything else will be on the original layer so you can select/deselect easily by using the Select on Layer command and/or using layer association in the toolpath.
Adrian, the problem is that I've got to nest these things and when I split things to different layers, even when selecting all the vectors, I get 400 sets of circles.
g.
g.
Shouldn't make any difference. Layers are preserved via nesting. If you need to group to maintain the relationship of parts then group after setting the layers and you can ungroup back to the original layers afterwards.
The issue is that if the holes are on a different layer, even if I select all (all the vectors are highlighted), the nesting operation is only grabbing the holes.
I'll keep at it.
g.
I'll keep at it.
g.
Then the other vectors you have aren't closed vectors. The nest will only operate on closed vectors. That's a different issue from selecting.
I got it all sorted out - I was stupidly forgetting the join vectors process. In my defense I haven't used Aspire in well over a year.
thanks all!
g.
thanks all!
g.
