Resize Job Dimensions
scovell
Model of CNC Machine: Shark CNC
Post by scovell »
Is there a way to resize the job dimensions of an existing project? If so, what are the steps?
I'd like to add a 1/4" to the width of an existing job.
Thank you.
Re: Resize Job Dimensions
Click on the Job Setup icon (1st icon, 2nd row under File Operations) or choose Job Size and Position from the Edit menu. You can then adjust the job size from there.
If you want to change the size of a vector you can use the Size tool (2nd icon under transform objects or press the T key) to do that. Be sure to uncheck Link XY if you only want to change the size in one direction.
scovell
Post by scovell »
Adrian, thank you so much for the guidance. :)
