zoom percentage
- Aussie
- Model of CNC Machine: Robotics Model 8
zoom percentage
Hi All,
Is there a percentage indicator when zooming in 3D display...... when do I know I am at 100%
Ron
Ron
Ron
Crafers Crafts
Crafers Crafts
- FixitMike
Re: zoom percentage
No way to tell. Your computer doesn't know how large your screen is. It could be any where from 9" high to 9' (or more) high. Programs that show a percentage zoom use their default as 100%, but that can be most any size.
Re: zoom percentage
Closest would be using the F or F6 key to fit the material to the screen or, selecting the components and using the Ctrl-F combination to fit the screen to the selection. Works in 2D and 3D.
- Aussie
Re: zoom percentage
Really ???
I can zoom whatever percentage I need with photoshop irrespective of my screen size, just thought it would be nice to see the actual job size in the 3D view at 100% to review the cut quality.
Ron
Crafers Crafts
Crafers Crafts
- TReischl
Re: zoom percentage
So, at 100% on a laptop monitor the image is maybe 8 inches tall.
On a large monitor, 55 inches, it would be ohhh, about 40 inches tall. Or does the 55 inch monitor show it at 8 inches tall?
Talked to my nephew about this, he is a big photo kind of guy. He was saying something about he can setup his ridiculously expensive monitor so that it reflects ACTUAL size of a photo, not a percentage. He paid a bit more than 5K for it about a year ago. I don't think he even lets his wife look at it, LOL.
Percentages mean nothing. A percentage is always the result of some other number.
Re: zoom percentage
Not exactly.Really ???
100% in Photoshop means 1 pixel in the image = 1 pixel on your monitor.
I just checked, and an 8x10 image in Photoshop, set at 72 pixels/inch, displays at roughly 5x7 inches at 100% on my monitor.
So 100% in Photoshop is not necessarily actual size, unless you adjust the pixels/inch of the image to match the actual pixel size of your monitor.
Re: zoom percentage
Lot of other factors will determine the cut quality in the view other than the size of the zoom. The most important for the toolpath preview would be the preview resolution selected and the size of the job in relation to the material. Both can have a massive impact on what you see in the preview so you wouldn't see the cut quality at 100% zoom anyway.Aussie wrote:Really ???
Re: zoom percentage
Hello,
From my point of view, display at 100% has very few interest in 3D. The only interest I see is having an idea of the actual size of the part. Sometimes useful as dimensions are not displayed in 3D.
When manufacturing parts up to 5m long, I never found the right monitor to get a 100% display.
Rhinoceros has a function to calibrate the display size. We found it very interesting and did calibrate the zoom. In fact, we never used it in years.
- stephenr
- Model of CNC Machine: Shopbot PRS Standard 48x96
Re: zoom percentage
Could this inquiry turn into a feature request? For example, when you first set up your working area, in inches or millimeters, you and the software both know exactly what size the defined model will be. But when you zoom in, the computer still knows what it is showing, but the user looses track of the relative scale. No need to have a percentage shown that means something different to each different computer and screen configuration. Why not have an option to apply a visual grid of points or lines definable by the user at whichever spacing deemed applicable to the model on the screen? This type of visual reference could be shown and hidden with a shortcut key. Just a temporary visual type of guide.
Stephen R.
Stephen R.
- mtylerfl
Re: zoom percentage
Grid display of points/dots already exists (and you can customize their spacing to whatever you want). Plus, there are both vertical and horizontal rulers as a handy reference. Plus, you can drag out reference lines from the rulers and snap in place for visual reference, as well.
- Model of CNC Machine: Thermwood CS-45 5 x 10
Re: zoom percentage
If I have a need, to have a photo Import, at 100 percent, actual size.
I always import, as bmp. this way it imports on to my material at actual size.
This becomes an issue when you scan a photo to import.
other wise when you import a jpg, file it seams to snap to size.
Maybe some one else, can explain it better.
Will Williamson willmade.com
Capac, Michigan
Capac, Michigan
Re: zoom percentage
I can second the monitor problem, just wish I was only producing stuff up to 5 metres in length
Most of what I do is way to big to be able to fit on a monitor at actual size, been working as a signmaker for nearly 20 years & have never seen this as an issue or wished that I could view at actual size
