Version 9 problem
stanv77
Model of CNC Machine: pdj cnc
Version 9 problem
Post by stanv77 »
Has anyone else had problems with the latest upgrade
I upgraded and I have had nothing but slow performance
since
Re: Version 9 problem
Post by Rcnewcomb »
No issues here
10 fingers in, 10 fingers out
another good day in the shop
No problems here and I don't recall anyone else reporting an issue like that on here either.
Which operations are you finding slower than previously? Have you checked Task Manager while Aspire is running?
lboss
Model of CNC Machine: 4x8 MotionMaster, Patriot, FAGOR Control
Post by lboss »
Running good for me.
Lynn Boss
vip-klaus
Model of CNC Machine: Wabeco F1410 LF-C HS; Sorotec AL1110
Post by vip-klaus »
Same problem like stanv77 here. Version 9.514 shows extremely slow reaction after each mouseclick. It's no more fun to work with.
Any ideas?
Klaus
Is that all the time or with a job loaded? Toolpaths? 3D components etc?
Have you checked task manager to see the memory usage, cpu load of tasks running?
vip-klaus
Post by vip-klaus »
I just did some tests: problem occures at 2-sides jobs.
- create a new 2-sided job
- create one single circle both on the top- and the bottom-side
- create a profile toolpath on both sides
Thats all. Calculating and preview lasts at least 10 times longer than before.
No problem with one-sidesd jobs.
Klaus
Yes, I'm seeing that as well now you've posted the steps.
rig gap
Model of CNC Machine: Home built aluminum and steel 3 X 4 CNC
Post by rig gap »
Getting the same delays...I thought at first it was my computer, but after some trials, I'm convinced it's caused by the newest patch.
Tailmaker
Post by Tailmaker »
Hm...I tried and did not see a difference. Same circle size at same center position an both sides.
Toolpath calculation takes a fraction of a second one sided or two sided.
Can somebody post the offending file?
Post by highpockets »
I'm seeing the same problem, doing a double sided job, but only a circle on front side.
Single sided job doesn't have the same delays.
Running 9.514
watsonswords
Post by watsonswords »
I just spoke to StanV on the phone and I do not have the problem on double-sided. Still quick here with the latest upgrade.
Tom Watson www.signsinwood.com
Tailmaker wrote:Hm...I tried and did not see a difference. Same circle size at same center position an both sides.
This file takes about five seconds to switch sides for me and some other operations (such as going to preview) take far longer than they would normally. Just loading it into a new session takes a while.
Slow File.crv3d
(215.5 KiB) Downloaded 53 times
mohamed
Vectric Staff
Post by mohamed »
I think we got to the bottom of this now. The issue is mainly to do with the simulation resolution and not project dependent. You'd notice a slowdown in opening any project, opening preview form, flipping sides, (x2 if it's two-sided). The slowdown is less noticeable with lower simulation resolutions.
Our apologies for the inconvenience! We're working on a fix and will be issuing a update as soon as possible.
Mohamed
Mohamed
4DThinker
Post by 4DThinker »
Thanks Mohamed. My PC with the update also shows a noticeable delay on any step of making a toolpath when the project is a 2-sided job. Once the PC responds things proceed at a normal pace. As if the code now stops to think for awhile before deciding to continue. I'll put off updating the install at work until a newer update is available.
