aspire looking up
scottart
Model of CNC Machine: Shark Pro HD and CNCrouterparts 4896
aspire looking up
Post by scottart »
after years of no problems with Aspire it has now started locking up every time I am using 3 D models. I have emailed Vectric but have no response.
The system gives me a lock up message and than shuts down Aspire. Sometimes the file is saved, but all work is lost back to any prior save I may have done.
IT also tells me that a diagnostic file has been saved and should be sent to Vectric. but I can not find that based on the location described in the message ( see attached photo)
Any help would be appreciated..
Re: aspire looking up
Post by highpockets »
Not sure about the error message, but see if this helps locating the dmp file.
ger21
Post by ger21 »
Try updating to the latest release.
esteeme1
Model of CNC Machine: Cobra 404 ATC; ROMAX WD-1; Shark
Post by esteeme1 »
Check if the correct files are created in the location specified. If not create folder.
Jim Darlas
"Can Do!"
http://www.esteemedwoodcrafts.com/
http://www.esteemedplaques.com/
redwood
Model of CNC Machine: Axiom Pro6
Post by redwood »
Most crashes I've had with other software usually involved the video/graphics card and drivers.
Mark
Pioneer, CA
Can you attach one of the files that is crashing?
RebeccaJ
Vectric Staff
Model of CNC Machine: Various
Post by RebeccaJ »
Hello Scott,
Could you please e-mail your issue and dump file, along with the steps you took before Aspire crashed to support@vectric.com and hopefully we can come to some conclusion as to what you are seeing.
Thanks in Advance.
Beki Jeremy
Senior Application Engineer - Vectric Ltd.
Mark
Vectric Staff
Post by Mark »
Hello Scott,
I replied to an email that may have been from you (the email in question originated from a rather strange looking outlook.com email address)
on Friday morning (before you posted this topic).
It might be an idea to check and spam folders for any email accounts that you have.
Cheers,
Mark.
