Photo vcarve to edgelit acrylic.
dwilli9013
Post by dwilli9013 »
Has anyone tried import a Phot vcarve file into aspire to carve into a piece of acrylic for an edgelit.
Just curious thinking about giving this a shot as I think it might look pretty trick. :lol: :lol: :lol:
D-Dub
Dwayne
Dwilli
Xxray
Re: Photo vcarve to edgelit acrylic.
Post by Xxray »
Aspire itself can create lithos, so its tough to see the need to import anything.
http://support.vectric.com/tutorials/V8 ... s_GEN.html
If you are talking clear acrylic I think the results would be disappointing. Colored acrylic maybe, but then it would not be edge lit but rather back lit ... I think it has been tried by some here, results are usually unpredictable and messy.
Doug
Post by martin54 »
As Doug has already said you will be very disappointed with the results, put your engineering head on & go & do a bit of research on light transmission :lol: :lol:
ChrisInEstes
Post by ChrisInEstes »
Seems like a Photo V-Groove has potential to work as an edge lighted acrylic piece. That's the only thing Aspire can't do that the other Vectric apps can, right?
Give it a try.
Chris
Xxray
Post by Xxray »
Repeat
Lithos are brought to life when a properly cut opaque material is backlit.
Thats 2 things you need, opaque material and backlight. Why you guys want to take it the other way and use transparent edge lit not sure, maybe something I just am not picturing correctly ,, But if you have any luck, post back.
I tried doing one in white plexi some time back and it was a gummy mess, I aborted it and never repeated, but thats not to say it can't be done. Clear plexi, just am not grasping the concept of why you would even want to try.
Doug
ChrisInEstes
Yeah, Aspire can create lithophanes, but it can't create Photo V-Grooves like PVC can.
So, the wider/deeper the cut with a V bit, the more light it'd pass, which may bring out the image, similar to filling the V grooves with a contrasting color shows the image.
Or... Am I missing something, and PVC's Photo V-Groove is off the table... for some reason... which I am missing...?
I've missed stuff before!
Chris
Xxray
Post by Xxray »
I dunno, "photo v groove" is not a term/process I am familiar with., I thought that was a typo.
From the sound of it, doesn't sound plexi friendly.
Doug
ChrisInEstes
glenninvb
Model of CNC Machine: homebuild / VCP 8.0
Post by glenninvb »
dwilli9013 wrote:Has anyone tried import a Phot vcarve file into aspire to carve into a piece of acrylic for an edgelit.
This is the only thread I remember seeing about PVC cut into clear acrylic and edge lit ,,,, I thought it was nice and may have looked better than the photo showed, edge lit acrylic is kind of hard to photograph in my experience, specially w/o a dimmer control
http://forum.vectric.com/viewtopic.php? ... ic#p129962
Aspire can do PhotoVCarve type cuts no problem. Import the photo, convert it to a component, create a 3d finish toolpath (raster at an angle) using a V-bit and a large enough step over to get gaps between the passes.
Post by martin54 »
I had even forgotten about that one Glenn :lol: :lol:
While I would agree that they are difficult to photograph well (for me at least :oops: ) I am not so sure that that particular job would have look much if any better if seen up close. If you look at the pictures you will see that the text looks a lot better than the actual picture.
I don't think that clear materials on their own give good results, photographs printed onto clear vinyl will always look washed out & faded, it's not until you apply them to a coloured background that they look better. I haven't seen a lot of photos engraved/carved onto a clear material but those I have seen have the same washed out look to them which is why I think Dyawne will be disappointed with the results.
I would also imagine that if you could get really good results then there would be a lot more pictures in the Gallery :lol: :lol:
