preview waste material will not delete
Xxray
Post by Xxray »
Trying to drum up a preview here and scrap material will not delete, saying I have tabs which I do not.
cut all the way through, cannot see any logical reason why it is doing this and is hobbling getting this thing done and shipped.
Doug
Re: preview waste material will not delete
Post by highpockets »
You have tabs in you cut. If you want to delete the waste to show the final product temporally remove the tabs.
Xxray
Post by Xxray »
Repeat - There are no tabs in the cut.
Doug
Sorry Doug, miss the no tabs part.
Xxray
Post by Xxray »
I triple checked before I posted, no tabs.
don't use them often but I think they do show in preview if present. Have had this happen before but more any annoyance now its an inconvenience. Ended up just doing a screen shot and sending that.
Doug
Try upping the Preview Simulation Quality under the Toolpath menu. Sometimes with a thin cut in relation to the size of the job there can be touching pixels at the lower resolutions which the software then basically treats as a tab.
mezalick
Post by mezalick »
Doug,
A simple answer would be to set the cutting depth .01 deeper than the thickness of the material
Michael
Michael Mezalick
https://carveddetails.com
mm@mezalick.com
kilrabit
Post by kilrabit »
try using a wider cutter
scottp55
Post by scottp55 »
Agree with Michael to duplicate the toolpath for preview only, and increase depth of cut.
Post by martin54 »
I have had this & found that increasing the Toolpath preview resolution as Adrian has suggested worked so it looks like either method has the same results :lol: :lol:
Only problem with increasing the toolpath resolution is that it will increase the time the simulations takes so if you have an older slow running machine then it can take a bit longer :lol: :lol:
Turtle49
Model of CNC Machine: 4' EZ-Router and Blurry customs SK25
Post by Turtle49 »
Looking at the image it does not look like you actually previewed the profile toolpath. Without doing that, there is no waste material. Maybe I am wrong but that is what it looks like...
Tim Hornshaw
www.HornshawWoodWorks.com
Xxray
Post by Xxray »
mezalick wrote:Doug,
Michael
Actually did, material is .5 and cut .51
I would think, if its through its through and doesn't really matter, in simulation, if its .51 or .91, the preview clearly shows when it is through.
Doug
sscooter
Model of CNC Machine: CamMaster Stinger
Post by sscooter »
Doug have you checked that the profile vector is closed and that there is no nodes out of place or perhaps a duplicate vector that is open?
Xxray
Post by Xxray »
Tim may be right, doesn't look like I even ran the profile, had a bunch of temp and revised toolpaths and might have got mixed up ... Closed that session long ago, but should be easy enough to replicate.
Doug
hdtheater
Model of CNC Machine: CNC RouterParts Pro 48x96
Post by hdtheater »
I know this is an older thread, but I ran into this same issue and the increase in preview simulation quality fixed my issue.
Among the steps I took to troubleshoot was increasing the bit size (which also fixed it). Oddly enough when I shrunk the bit size, it barely even registered in the preview.
-Eric
