I have never seen this problem in all the time I have used Aspire. The right line cuts twice when using outside and inside machine vectors. Only once when on machine vector is used. I would like to understand why it is doing this.
I am still using 4.5 version.
Cuts right line twice.
- Model of CNC Machine: MechMate
- Save Test.crv3d
- (18 KiB) Downloaded 122 times
Re: Cuts right line twice.
If you go into node edit mode and drag the bottom node over on that line you'll see the problem. It's basically a double line as far as Aspire is concerned because of the overlap.
If you zoom in enough you see the line has an extra point.
(Adrian beat me to it!)
- TReischl
The dreaded Double Line Whammy!
Thank you. I knew it was a problem but I could not find it. It is very small.
- Xxray
TReischl wrote:The dreaded Double Line Whammy!
I'm singin those Double Line Blueeeeesssss !
Doug
- TReischl
"Nobody leaves til dey sing da blues."
Is'n that a line from Adventures in BabysittingTReischl wrote:"Nobody leaves til dey sing da blues."
- TReischl
You win the prize!
