Mirror not working
Robert M
Mirror not working
Post by Robert M »
I've used the mirror command many times in the past. I just tired it with version 4.5 and can't get it to work. I want to mirror a circle created in the lower left corner and create a copy of that object in the lower right corner. I have the create mirrored copy checked. The only thing that happens is I get my circle flipped to the opposite side so I still only have one circle. Never had any issues before. Closed Aspire and ran a new instance of it with the same issue. What am I overlooking?
Robert M
Camaster Mini Cobra
Aspire 4
Zbrush
Adobe Photoshop / Illustrator
Westminster Maryland
mezalick
Re: Mirror not working
Post by mezalick »
Is the box "Create mirrored copy" checked ??
Michael
Michael Mezalick
https://carveddetails.com
mm@mezalick.com
Robert M
Post by Robert M »
It sure is
Robert M
Camaster Mini Cobra
Aspire 4
Zbrush
mezalick
Post by mezalick »
I thought it might have been,,I've made that mistake many, many times..
Just needed to eliminate the obvious
michael
Michael Mezalick
mm@mezalick.com
4DThinker
Post by 4DThinker »
Could the disappearing original be hiding on an "off" layer?
Robert M
Post by Robert M »
I tried running the same file on my laptop and it works fine. The computer in my shop has a three monitor setup. Two monitors are being used for Aspire. Perhaps that's the issue.
Robert M
Camaster Mini Cobra
Aspire 4
Zbrush
Post by TReischl »
Hmmm, usually if a program is running on the "main" monitor everything will work fine. There are a few programs I use that go a bit berserk when they are run on an extended monitor. Try running it on the main monitor?
PaulRowntree
Post by PaulRowntree »
As a follow up to Ted's comment, make sure it really is gone : force a screen refresh (minimize the maximize the window) to see if it is gone or just not drawn.
Paul Rowntree
Robert M
Post by Robert M »
I am running from the main monitor and tried the min/max window procedure. Tried it again this evening with the same results. I also run Adobe Illustrator and ViaCad on the same computer without any problems. Just not sure why the mirror command does not work.
Robert M
Camaster Mini Cobra
Aspire 4
Zbrush
tmerrill
Model of CNC Machine: ShopBot
Post by tmerrill »
Robert,
What happens when the select the first circle and use the horizontal copy/mirror shortcut: Ctrl-Shift-h?
Tim
Robert M
Post by Robert M »
Tim
Your method works as expected.
Robert M
Camaster Mini Cobra
Aspire 4
Zbrush
