When I get a project set up to carve the program and hover over a toolpath, it gives a run time. But I noticed that the actual run time is approximately one half of that time. Is there a spot in the program that can be adjusted to have the program show closer to the cutting time on my machine?
Jim
Aspire running time
Re: Aspire running time
Jim,
You need to set the Scale Factor and Rapid Rate for your machine. This FAQ will walk you through it:
http://support.vectric.com/aspire-quest ... ining-time
Over time you can develop different Scale Factors for the type of toolpaths you are running (2D or 3D for example) but realize it will always be an estimate.
Tim
Tim
- Model of CNC Machine: Romaxx WD1
Tim
Appreciate your response. I'm going to find out what my rapid rate should be. I'm running Mach 3 and not sure where I could adjust the rapid rate as well as the scale factor.
Any help would be greatly appreciated.
As you can tell by now I have a lot to learn.
Jim
Jim
Hi Jim,
I can't help you with Mach 3 settings, but in Aspire you would click on the icon circled in the first snip and adjust the settings and units shown in the second snip. Maybe with this the FAQ I linked above will make more sense.
Tim
Tim
