opening dxf file
- Model of CNC Machine: prs standard
opening dxf file
A potential client sent me a dxf file that I can not open! She says it was made in (illustrator) can someone who has this program please open this and save it in a version that aspire 4.0 can open. I just locks up aspire 4.0? I was able to open it somewhat in part works and it looks like it has many duplicate lines???? Thanks Don
- Joans scroll 4.dxf
- (1.01 MiB) Downloaded 151 times
Re: opening dxf file
Try this it saved as eps
- Ms Wolffie
If it was created in Illustrator, it should have saved as a .ai file.
Whatever it is, it is no wonder it locks up Aspire, it is enormous.
About 5 feet long and 1 inch wide.
It is also very rough, it will take you ages to clean it up.
Anyway, this is what it looks like You can take it from here.
Cheers
Wolffie
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
- Zeropoint
- Model of CNC Machine: Heiz 1400 T
Hi All
Corel X5 & on will also work with ai & dxf files.
Just have a care when it prompts you how to handle nodes & units etc.
Rgds
Mark
Rgds
Mark
Zeropoint CNC
http://www.kashaan.co.za
- ssflyer
- Model of CNC Machine: ShopBot PRSAlpha 96x60
Wolffie's right about cleanup. Here's what the vectors look like without the fill. BTW, I think this issue is caused by using "Fill" in Illustrator, it seems to create the offset vectors. Try and get the file (as AI or EPS, preferably) from the client without fill turned on, and you should have a much better file.
Ron Sloan
how about this eps.
- ssflyer
Martin,
I don't see any difference - still filled, and multiple vectors, overlapping...
Ron Sloan
Ron, that's strange, I've just downloaded the last one I posted & yes it is filled but it doesn't contain multiple vectors when I view it in wireframe with my software. The small file size would indicate that it is a lot less complex as well.
- Model of CNC Machine: Shark Pro Plus HD & Custom built 4x4
Martin,
I downloaded the file you posted and didn't see multiple vectors. I ran a shallow profile cut and it looked fine to me.
You were lucky. The vectors posted have a few issues that could cause issues with certain toolpaths. There are a few loops and stray vectors and some of the segments that should be smooth are not.I downloaded the file you posted and didn't see multiple vectors. I ran a shallow profile cut and it looked fine to me.
Tim
Yes sorry Tim, should have made myself clear. It was literally a 2 minute job to get rid of most of the unwanted rubbish, still needed a bit of clean up & node editing before cutting but should have been good enough to be able to give the customer a visual & quote. I wouldn't spend the time cleaning it up perfectly unless I knew I had got the job.tmerrill wrote:You were lucky. The vectors posted have a few issues that could cause issues with certain toolpaths. There are a few loops and stray vectors and some of the segments that should be smooth are not.I downloaded the file you posted and didn't see multiple vectors. I ran a shallow profile cut and it looked fine to me.
Tim
- Model of CNC Machine: Home built designs - 3'x4' and 5'x12'
When tracing an image by drawing vectors with a mouse, these loops and other jagged anomalies can also be created by an electrically "noisy" mouse button switch. Replacing the mouse with a newer one will usually help if the original mouse was already well used. Switches do have a limited useful life. Dirt cheap mouses usually don't have high quality switches.
CarveOne
CarveOne
CarveOne
You're right, but the multiple vectors from the initial file are gone. The op has something better to work with now.tmerrill wrote:You were lucky. The vectors posted have a few issues that could cause issues with certain toolpaths. There are a few loops and stray vectors and some of the segments that should be smooth are not.I downloaded the file you posted and didn't see multiple vectors. I ran a shallow profile cut and it looked fine to me.
Tim
Running a vee bit with a .020" pass only showed a couple of strays that were barely visible on a 14" laptop screen. It's useable but the file does still need some clean up.
Thanks everyone for your help with this . I also tried scanning the original photo and creating vectors from that . also a lot of node editing . I will post a finished photo if I get the job . Hope all are having a good new year. Don
- ssflyer
Oops, sorry Martin, I had inadvertently reopened the first file! Yours is much better. My bad!
Ron Sloan
