Need help with Aspire running on a Mac
TonyD
Post by TonyD »
I just moved Aspire 3.5 from a PC to a new Macbook Pro. Running on Win 7 using Parallels. All seems to work normally until I try to choose a post processor when saving the tool path. The default that comes up is:AXYZ 4010 ARC (inch) (*NC). When I try to change it, Aspire, Parallels and Windows all shut down.
Tony
Re: Need help with Aspire running on a Mac
Post by Rcnewcomb »
I'm running Aspire on a Mac under VMware/Win7 with no issues. Sorry I can't help with Parallels, but I do know it runs well in my environment.
10 fingers in, 10 fingers out
another good day in the shop
tonydude919
Model of CNC Machine: cnc mako shark ext bed with HD 5 gantry
Post by tonydude919 »
I have aspire on a mac and works fine using parrallels. Been using mine for over a year now.
Tony
BobA
Model of CNC Machine: Camtech
Location: Nanaimo, Vancouver Island, British Columbia, Canada
Post by BobA »
Just a passing thought, but why don't you move AXYZ 4010 ARC (inch) (*NC) temporarily to another folder out of the way and see what happens? I run Windows 7 with Parallels and have no problem. I would love to hear if it works out for you!
Bob
PaulRowntree
Post by PaulRowntree »
As an alternative to BobA's suggestions, try moving everything out of the PP folder (to a safe location), except the PP that you plan to use.
Aspire saves the name of the PP last used in the Registry as theDefaultPP_Name under
HKEY_CURRENT_USER\Software\Vectric\AspireV4\Toolpaths
Perhaps your emulator shell is refusing access to the registry ? Are there permissions you can ease up on?
Paul Rowntree
joeymiz
Model of CNC Machine: Axiom pro 4
Post by joeymiz »
I am running VCarve Pro on a mac under parrallels and running fine, but I find that I cannot use the delete key and certain other keys. Is there a combination of keys that will work?
Delete is fn-backspace.
Wayne Locke
Model of CNC Machine: Shopbot
Post by Wayne Locke »
On an extended Mac keyboard the larger Delete Key does not work but the smaller Delete key to the right does.
