working on a project with engraved letters in wood. The letters are in an 8 x .75 text box and "pocketed" in the wood with a .125 ball nose.
Any tips on how to sand those?
tricks for sanding inside engraved letters in wood?
- Model of CNC Machine: Legacy
Re: tricks for sanding inside engraved letters in wood?
Use a dremel with either the scotchbrite "mops", or diamond burrs. They are available at big box hardware stores, or online at eBay and other online merchants.
- gordread
- Model of CNC Machine: CNC Professor HDX
I use a 'sanding mop' as well as the diamond bits as above.
http://stockroomsupply.ca/shop/sanding-mops.html
- juan
Heej there,
I`m using bristle dics from 3m you can take 1 or 3 dics at the same time
good luck!
http://www.foredom.net/ak4515.aspx
greetz Juan
good luck!
greetz Juan
There are also wire and plastic brushes that work with dremel tools:
A dremil mandrel with a piece of scotchbrite pad works almost as well as the mini sanding mops.
-- John
-- John
- gordread
Oh, that's a great idea. I'm going to have to try that.jseiler wrote:A dremil mandrel with a piece of scotchbrite pad works almost as well as the mini sanding mops.
-- John
Gordon
