Angle head
Angle head
Hello,
is it possible to make a toolpath in Aspire for angle head like this: http://tinyurl.com/axag393 ? I don't even dream about turning the head over the Z axis it will be in one posision over the X axis.
I would like to use it for makeing the pockets for hinges (like those http://tinyurl.com/a2mknpd).
Kindest regards,
expart.
Kindest regards,
expart.
Re: Angle head
Yes, you can, as long as the tool diameter is the same as the height of the hinge.
However, you need to tell aspire you're using a normal vertical tool, and all entry and exit moves are completely up to you. And the preview will show something vompletely different then what you'd actually be doing.
You basically just draw a 2D vector. Start outside the door, at one end of the hinge. Move in the correct depth, move over, and back out. So, the toolpath will just be a 2D "U" shape. If you need to cut it in multiple passes, then you'll need a separate vector for each pass.
If you make any mistakes, results will likely be very bad.
Re: Angle head
It will be complicated to use tool with the same diameter
Maybe somebody can make a Gadget? Please?
Best regards,
expart.
Best regards,
expart.
- Leo
Re: Angle head
I think this is where is would be nice to have g-coding skills. I programmed in g-code for many years before ever using cam.
I don't know how, but maybe you can swap around the "Z" axis with either the "Y" or "X" depending on how you machine is setup.
You could program in Vectric in a normal way - but swap the axis plugs on your machine.
I dunno - but - there must be some creative way to do it.
www.leosworkshop.com
Re: Angle head
I expect Mach3 has an extension of some sort to swap axis in the code around. It's in the ShopBot software and most of the time whatever I've seen in the Shopbot software is in Mach3 somewhere as well.
- Model of CNC Machine: weeke bhp200
Re: Angle head
Would you not need , a left and right hand cutter to avoid chip out on exit
Harold
Harold
Re: Angle head
I'll try with swaping axises. Thanks!
What do you mean?4240harold wrote:Would you not need , a left and right hand cutter to avoid chip out on exit
Harold
Re: Angle head
Hello expart, You could try using the following g code to swap the plane selection:
G-code definitions found at the following page:
http://linuxcnc.org/docs/html/gcode.html
- Model of CNC Machine: CAMaster 508 ATC
Re: Angle head
unless you are wanting to use it for some large production runs then machinery makes sense, we have made jigs for the SOSS hinges and it takes minutes to rout, a CAMaster has the ability for the Zhead to extend beyond the table bed, this allows for end boring,, a shopbot can do this as well
Re: Angle head
Sorry expart
Just looked at first picture of aggregate and thought you were talking about butt. Hinges
We cut out butt hinges on edge of doors using an aggregate with left and right rotation cutters
Don't know how this could be done in aspire, but it would be a nice addition
I was asked once to carve a names on table edges for a restaurant
Re: Angle head
I can imagine a lot of tasks which could be solved easier with such a head - dowels, etc.. agree that it would be nice (vectric team, can you agree?4240harold wrote:Sorry expart
Re: Angle head
The issue I could see with an angled head like that is that you would need to get the material raised off the machine bed as the distance between the bottom of it and and the centreline is much greater than the likely thickness of the material.
Not sure how easy/possible it is do on other machines but on a ShopBot it's possible to clamp material vertically at the end of the table which makes edge routing very easy. I've done it several times with pieces the size of cabinet doors although I could go as big as 50" x 36" x 4".
- Model of CNC Machine: Masterwood Atlas KL
Re: Angle head
There hasn't been an update to this post in a while. Has there been any progress with the use of these tool holders? I have a fixed 90 and adjustable aggregate I was hoping to be able to use with Aspire. I also have a fixed 90 boring spindle on my CNC I was also hoping to use. Any help from those who use these tools would be helpful.
Thank you.
Thank you.
- IslaWW
- Model of CNC Machine: The Ultimate Woodworking Machine
Re: Angle head
Vectric software does not support aggregate heads out of the box. That said, with some careful thought, clever toolpath design and maybe even throwing some C axis rotation into the tool notes section, this can happen with most control software brands.
Gary Campbell
GCnC Control
GCnC411 (at) gmail.com
GCnC Control
