Epicycloid Gadget
Ryan Patterson
Model of CNC Machine: ShopBot
Epicycloid Gadget
Post by Ryan Patterson »
This gadget is more for fun, it creates a polar cycloid. It is almost like a spirograph but a little simpler. Here is a link that explains a cycloid and is where I got the equation http://en.wikipedia.org/wiki/Cycloid . The only type of toolpath I can see for this would be Profile on the line.
To use first select vectors to base the size they can be of any size or shape. The gadget uses the bounding box size to determine the width and height of the Epicycloid shape.
For those that may have missed earlier gadget postings.
Tangents Gadget: http://www.vectric.com/forum/viewtopic.php?f=27&t=12850
Valance Gadget: http://www.vectric.com/forum/viewtopic.php?f=27&t=12648
Fluter Gadget: http://www.vectric.com/forum/viewtopic.php?f=27&t=12720
Epicycloid.zip
(11.06 KiB) Downloaded 366 times
Ryan Patterson
www.cabinetpartspro.com
info@cabinetpartspro.com
dhellew2
Re: Epicycloid Gadget
Post by dhellew2 »
Thanks, Dale
Young = time, no money
Old = money, no time
Dale
ssflyer
Post by ssflyer »
Cool gadget, Ryan - brings back memories! Think I'll try it for some soapstone trivets!
Ron Sloan
zeeway
Post by zeeway »
Thank you, Ryan. Will lead to some creative v-carving, I am sure.
Angie
dansfoundry
Post by dansfoundry »
Thank you Ryan I downloaded the file and unzipped in the vectic gadget folder but when I try to open it in Aspire I get the message "This program cannot display the webpage " what am I doing wrong? Dan
Ryan Patterson
Dan,
It sounds like some of the files are in an incorrect location. There are a total of 3 files for this gadget Epicycloid.VectricGadget , Epicycloid.htm and Epicycloid.PNG. The Epicycloid.VectricGadget file should be located in the Gadgets folder the other two files should be in a folder within the Gadgets named Epicycloid. I hope this helps
Ryan Patterson
dond52
Post by dond52 »
Thank You so very much for this gadget. It is so cool. Trivits as Ron mentioned will be great.
The different border or corner possibilities are limitless. Thanks again ! :P
dansfoundry
Thanks Ryan for the good work and you where right about the files being misplaced everything works now. Dan
jardin33
Model of CNC Machine: Shopbot Buddy 48
Post by jardin33 »
I love gadgets,
let the imagination begin.thanks :idea:
Raymond
JaR-Din Woodworks
Rick O.
Model of CNC Machine: CNC router
Post by Rick O. »
Will these Gadgets work with V-Carve, or only Aspire?
RickO
They work with both. Ryan has posted a link in the VCarve forum as well.
Post by adze_cnc »
I came across this gadget some time ago and thought it might be useful. I needed it for a project but found out that it is in older gadget format. I managed to extract and update the code so that it will run under the current gadget SDK (mostly sorting out global and local variables).
If Ryan gives his assent I can post that updated version here.
Steven
jimandi5000
Post by jimandi5000 »
Hi Ryan,
Very nice job on the code.
Nailed IT.png (23.28 KiB) Viewed 4411 times
Jim
