This is one big sign for me. It is 21 feet long by 36 inches wide.
Steel frame cut in 2, ie:2 x 10.5 feet each, bolted,
paint is baked (paint powder) color is rustic copper.
1/4 '' rods.
I used a 1 1/2'' V-90 fit for the letters, and 1/2'' for the
roughing and 1/4'' balled nose for finishing.
Letters are 2'' sign foam,glued to 3/4'' plywood.
fruits are sin foam 2'' total 4'' high also glued to plywood.
The paint for lhe letters is copper enamel for car,contour
is acrylic paint so it is fot the back of the letters.
The fruits are acrylic solid colour and finishing is air brushed.
everything is attached with, to the frames rod with copper plate
and slainless steel screws.
One word about gluing sign foam to the plywood, i used
an epoxy laminated # 8090 i covered both surfaces to
prevent water between the 2 ,and after it was dry, i did
cover the sides and the back of the lettering and the fruits.
Doing it that way i extend the life of my sign.
The fruits were supplied by Vector clip3d ,my friend Norbert.
I would like to thank Vectric for their fantastic program Aspire
everything were cut trough Aspire.
Tribute to my friend Francis for the air brushed.
one of my best sign thank you Vectric
Re: one of my best sign thank you Vectric
Tres chic Gerry,
Is The Abby's Orchard the name of a fresh fruit and vegetables market or perhaps even a real orchard?
Gerry in Belleville, ON
A Legend in His Own Mind
- Model of CNC Machine: CAMaster 508 ATC
i enjoy this kind of work !! excellent
- Model of CNC Machine: CAMaster 508 ATC + Rotary
Very nice work indeed
Mick Martin
Aspire 4.015
http://mickmartinwoodworking.com/
Aspire 4.015
To complete the subject here is a picture of the sign installed with the help of a friend and customer.
- photo vectric.jpg (8.34 KiB) Viewed 434 times
I rather be the leader,than the follower
gerry pic is too small !
- Model of CNC Machine: AXYZ 5010
