hI
I have just purchased Aspire 3 and woul like to know if i have made a file on Aspire 2.5
saved my file and then opened it in Aspire 3. Why in Aspire 2.5 it takes 02:44:37
and in Aspire 3 it takes estimation time 03:12:22.
What am i doing wrong.Gerry
Want to know
Want to know
I rather be the leader,than the follower
- esteeme1
- Model of CNC Machine: Cobra 404 ATC; ROMAX WD-1; Shark
Re: WANT TO KNOW
not sure of terminalogy but have you changed your time ratio value in Aspire 3?
Jim Darlas
"Can Do!"
http://www.esteemedwoodcrafts.com/
http://www.esteemedplaques.com/
"Can Do!"
- RoutnAbout
- Model of CNC Machine: 2004 48x96 PRT 5hp Spindle
Re: Want to know
Gerry,
Jim is talking about the Scale Factor on the toolpath tab.
- esteeme1
Re: Want to know
Yes the Scale factor under the Toolpath tab and Estimated machine time sub menu.
Jim Darlas
"Can Do!"
"Can Do!"
Re: Want to know
IF the scale factor is the same it may be worth checking the feed rates in case the tool databases don't match.
Most likely to be the scale factor though as it's easy to overlook when loading a new version.
