use of spring loaded drag bit for acrylic
ltasset
Model of CNC Machine: Axiom Pro
Post by ltasset »
I am using a 90 degree spring loaded drag bit to draw a grid on acrylic for a game. I am having difficulty getting it to cut deep enough so that the grid shows once the acrylic is turned over. Does anyone have a suggestion to solve this?
Tex_Lawrence
Model of CNC Machine: Shapeoko3XXL; JTech7W; V-CarvePro 12.009
Re: use of spring loaded drag bit for acrylic
Post by Tex_Lawrence »
My drag bit is only suitable for edge-lighting acrylic. It doesn't remove much.
I would use a 90 or 60 vbit for what you are doing.
Tex — Crooked Wood Products
Drag bits don't generally cut very deeply, you might be better using a V bit or a ball nose bit for something like this as has already been mentioned. The other thing you could try is putting a heavier gauge spring in the drag bit. I have a range of different springs for my drag bit so I can use it for different materials :lol: :lol:
FabLab Wageningen
Model of CNC Machine: Ooznest Workbee 1500x1500
Post by FabLab Wageningen »
It depends on your line width.
Drag bits should be able to make finer lines. If you can live with a little bit wider, certainly use a V-bit. We have used 60-degree V-bits with quite good results.
Marcel.
