Hi all,
Got a long cut that I've been doing using a 3d roughing pass and the bit broke annoyingly...!
I'm trying to work out if there's any tricks to continuing roughly where I left off - I'm using Carbide motion which seems fairly limited in this respect, so I was wondering if there's anything I could do in aspire to achieve the same result?
Tricks for continuing cuts after broken bit??
- HandsOnKatie
- Model of CNC Machine: Shapeoko 5 Pro
- Tex_Lawrence
- Model of CNC Machine: Shapeoko3XXL; JTech7W; V-CarvePro 12.013
Re: Tricks for continuing cuts after broken bit??
Nothing I can help you with about CM. Its probably too late for your current situation.
However, switch to gSender by Sienci, and you will get a function for resuming at line number; along with many other features.
https://resources.sienci.com/view/gs-installation/
https://forum.sienci.com/
Tex — Crooked Wood Products
- HandsOnKatie
Oh great tip, that looks excellent! I'm thinking actually I could just load my existing gcode in that and it 'should' work?? Then I could skip to the rough place and carry on hopefully....!
- Tex_Lawrence
Its possible, but use ncviewer or equivalent to maybe see where that point is in the gcode. I'd be careful about gcode produced by a post processor that works with CM, but its your experiment.HandsOnKatie wrote: ↑Mon Apr 22, 2024 11:25 am... I could just load my existing gcode in that and it 'should' work?? ...
gSender will give you a view of the gcode, so perhaps you'll be able to see on screen where to re-start. I've never done that, though.
- HandsOnKatie
Yeah, it's good counsel - although as I was doing a 3d roughing pass from vectric aspire, it's pretty predictably going back and forth in a raster motion, so I know it have got to the third layer pass and got about 70% through that, so if I start it we'll before that - eg 50% through the third layer, then it can cut air for a bit and I can check it's aligned before it starts to cut for real and carry on.... at least that's the theory ...
