Sliding dovetail for draws
edcross
Model of CNC Machine: Fineline automation 50" x 50"
Post by edcross »
I would like to make sliding dovetail, center mount draw slides . I was going to cut the pocket with a straight end mill , then run a dovetail bit at full depth with leads at both ends . Any other ideas , dado with dovetail bit , but it does not offer leads in gadget.
Ed
ohiolyons
Re: Sliding dovetail for draws
Post by ohiolyons »
Look into the keyhole gadget, it might work.
CNC in Kettering, Ohio
edcross
Post by edcross »
Keyhole gadget does not work , starts in middle of work piece , will try vector tool path
Ed
ohiolyons
Post by ohiolyons »
Ignore the circular comment see photo.
keyhole sliding.crv3d
(24 KiB) Downloaded 18 times
This will allow you to use dovetail bit, but not sliding since lt only does vertical or horizontal lines.
edcross wrote:
Wed Jan 25, 2023 8:11 pm
Ed
This topic has come up quite a few times. Do a forum search for "sliding dovetail".
edcross
Post by edcross »
I found that you can use the vector line in the center of the stock and use the node editor to extend the line of the dovetail bit on both sides,( the diameter of the cutter )
Ed
