Hi,
I have noticed that if I attempt to use the Chamfer gadget in this version (10.515) it does not work correctly,,, However, if I us it in version 10 it is quite O.K.
Typically, in version 10,515, if I attempt to chamfer, at 45degrees, the edges around a square I get a chamfered square with a additional cross machined diagonally.... very odd!
I know I can use the "Chamfer" in Toolpath Operations but I am curious as to why the gadget does no work correctly in this later version.
Soapy
Chamfer Gadget in Version 10.515
- scotttarnor
Re: Chamfer Gadget in Version 10.515
Maybe because 10.5 has the chamfer toolpath and does not require the gadget?
https://m.facebook.com/vectric/videos/n ... 753412816/
Scott T
@scottscnc
@scottscnc
It's not doing that for me in 10.515 with the gadget. Do you have a file you could upload?
- Model of CNC Machine: Heiz High Z Machine German manufacture
As requested
- Fault in Chamfer Gadget.crv3d
- (326.5 KiB) Downloaded 21 times
Hi Scottanor,
I use both the chamfer gadget and the chamfer in the Toolpath Options ....
If the gadget worked well in version 10 I would expect it to work in version 10.515
I see no reason to add it to version 10.515 if it does not work on my machine
One reason why I use the gadget version is that I find I have the option to use end mills in this particular version and I have difficulty specifying an end mill in the Toolpath Options "Chamfer".
Soapy
Soapy
