Rabbiting around the edge of a rectangle
David Corrigan
Model of CNC Machine: ShopBot Desktop
Post by David Corrigan »
I know there must be an easy way to accomplish this but can someone tell me the best way to create a rabbit completely around a rectangular piece of wood?
Re: Rabbiting around the edge of a rectangle
Lots of variations depending on whether you have a tool that can do it one or whether you need multiple horizontal passes.
If the tool is wide enough then use an outside profile toolpath with a vector that is inset from the edge of the material by the size of the rabbet.
If the isn't wide enough then use a pocket toolpath. The outside vector of the pocket needs to be larger than the material by enough that you don't get "islands" left by the round shape of the tool in the outside corners.
David Corrigan
I knew it had to be easy. Thank you Adrian.
TheRealJustMe
Model of CNC Machine: Shark SD100 & Shapeoko 3 XXL
Post by TheRealJustMe »
Adrian,
Seven years later & your tip is still helping out! I've been racking my brain trying to figure this out for the last couple of days.
Thank You.
Jim
