Aspire dxf to fusion360
RhoTu
Post by RhoTu »
Good morning all,
I am fairly adept at aspire and like designing items within it. I need some help though with getting a design into other software to be able to extrude a design and create a stl file for slicing for a 3d print.
For some reason this design needs something different than what I have been doing. Can someone explain what process I need to accomplish this task?
Attached dxf file exported from Aspire.
Rocker.dxf
(13.23 KiB) Downloaded 22 times
Re: Aspire dxf to fusion360
Maybe I'm being a bit dense but I'm not seeing what the problem is.
Post by highpockets »
The dxf imports just fine, however if you're wanting to extrude it there's a problem. The outline vector is open, close the vector export again and then import into other software.
RhoTu
Post by RhoTu »
John, I swear I checked that 3 times. Thank you for taking the time to look at this. As usual, my fault.
RT
No problem,
There are two add-ons for other software that you might want to take a look at. ConnectTheDots and SketchChecker. other software doesn't have nearly the nice tools for dealing with vectors and in this case open vectors that we have come accustom to in Vectric products. It's easier to find the problems in Aspire or VCP then export to other software.
