Pocket Toolpath
- Model of CNC Machine: Next Wave Shark 510
Pocket Toolpath
I'm trying to use the pocket toolpath strategy on a file, and I can't get the software to pocket the areas between the emblems, so that the emblem and text protrudes out. The logo is a Pittsburgh Steelers emblem. I've been fighting this thing for days. i guess it goes without saying I'm a Newbie.
Thanks for any and all help.
Jim
Jim
- SteveNelson46
Re: Pocket Toolpath
Uploading the file or a picture would help us understand what you are trying to do. If I understand your explanation correctly, you need to select the outside perimeter of the pocket. Then, select all of the vectors inside of the pocket that you don't want cut out. You may need to outline the graphics ether manually by drawing a vector around them or use the "Create Vector Boundary Around Selected Components" tool under the Model menu. In the pics below, the first shows the selections and the second shows the outcome.
Re: Pocket Toolpath
Thanks Steve. I’m new to this, so I’m trying to figure out how I upload a picture of what I’m doing. Once I figure it out, I will show what I’m up against.
Jim
Jim
- sharkcutup
Re: Pocket Toolpath
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
Re: Pocket Toolpath
Is this similar to what you are trying to accomplish???
The ones I looked at the shapes were just about touching each other which I suspect is what is causing the problem with the pocket toolpath, where did you find that Logo with them so far apart?
Re: Pocket Toolpath
I cant seem to find a way to take a picture of my 2d drawing. I used arcs and and mirrors to draw the emblem. The emblem ends do touch, so that must be where my problem lies.
Jim
Jim
- sharkcutup
Re: Pocket Toolpath
I created it all from scratch I just used an image as a guideline to go by.
A photo or copy of the image the Op is using would have been better guideline to go from then I could easily determine the Op's problem issue.
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
Re: Pocket Toolpath
Windows has a built-in snipping tool for taking screenshots and saving the image to a file.I cant seem to find a way to take a picture of my 2d drawing.
The file can be uploaded as an attachment to the Vectric forum.
Re: Pocket Toolpath
i'm new to all of this, but I'm sure I should be able to get this to do what I want.
thanks for any guidance or direction that you might offer.
Jim
Re: Pocket Toolpath
Select the text, the diamonds, and only the inner circle. If all these things are closed entities the pocket toolpath should do fine.
- sharkcutup
Re: Pocket Toolpath
Example sample with the diamonds closer together. Really no need to round the stars point. The Pocket Toolpath works fine here when using three different size bits for the process. .25" End Mill for hogging the material away, .125" End Mill for cleanup, and a .0625" End Mill for the Fine Detail Cleanup around the Characters of the Steelers name.
Sharkcutup
V-Carve Pro 11.554
V-Carve Pro 11.554
