DXF Files
ColoradoDave
Model of CNC Machine: Legacy Maverick 3x5
DXF Files
Post by ColoradoDave »
Can anyone tell me if it is possible to output the tool paths created in V-Carve Pro to a DXF file? How about a PDF file?
Thanks.
Re: DXF Files
No they are the wrong type of file for that sort of thing.
Re: DXF Files
Post by Rcnewcomb »
You can export your vectors as DXF.
What problem are you trying to solve by converting G code to DXF?
Re: DXF Files
It's definitely possible as I've done it in the past but why do you need to?
I had a very specialised need that required very specific toolpaths so some more info to see if you're in a similar position or if there's some other process that would do what you want would be helpful.
Jan.vanderlinden
Model of CNC Machine: Xcarve
Re: DXF Files
Post by Jan.vanderlinden »
Yes you can export in either DXF or PDF.
I use PDF to email drawings to my customers that don't have CAD software.
Edit.
Sorry, I just saw that your question related to toolpaths.
Toolpaths don't work with PDF.
GATE PROJECT.pdf
(60.84 KiB) Downloaded 13 times
Re: DXF Files
Post by adze_cnc »
There’s G-Code Ripper. It’s been able to convert g-code paths to dxf for close to 10 years now.
When I first saw that ability I thought cooooollll but, tellingly, in 9 years I’ve never found a reason to use it.
Re: DXF Files
Adrian wrote:
Wed Mar 29, 2023 2:22 pm
I have read about other software that will convert a g-code file into a DXF file but I didn't realise that you could do it from within the Vectric software. There have been a few posts over the years & I thought it always involved the use of some other software.
Re: DXF Files
martin54 wrote:
Wed Mar 29, 2023 4:29 pm
With the right post processor you can create a DXF file directly from the toolpaths. That's what I did rather than converting the generated code. I used a v-carve toolpath to generate lines within a series of shapes for led strips. I've thought of many different ways of doing it since but that worked really well.
Jan.vanderlinden
Re: DXF Files
Please disregard my previous post.
I completely misunderstood the question.
Leo
Re: DXF Files
Post by Leo »
If you post the g-code you can open it in any text editor.
Then you can print to PDF.
AboveCreations
Model of CNC Machine: i2r B22
Re: DXF Files
Post by AboveCreations »
ColoradoDave wrote:
Tue Mar 28, 2023 10:01 pm
Thanks.
As others have asked... what are you trying to accomplish or resolve by needing this feature. No one else seems to have a need or reason. I am curious why you would want this.
