Slop for model jeep tire
- Model of CNC Machine: CNC Shark II
- sharkcutup
Re: Slop for model jeep tire
Something Like This???
Sharkcutup
Sharkcutup
V-Carve Pro 12.005
V-Carve Pro 12.005
Yeah. It’s really unclear what you are looking for. It took me a bit to figure out is was a “slope”. There were also many 1/8-s didn’t add up.
If your slope is going to be as you’ve started with the moulding toolpath then you are going to need to create 30 toolpaths. I stopped after 4:
If what you are looking for is a pseudo beveled pinion gear then you are going to use the “Fluting Toolpath” as I did here:
I just selected the 30 radial lines and used the following parameters:
- sharkcutup
Could end up like this!! It all up to the users imagination!!
Sharkcutup
Sharkcutup
V-Carve Pro 12.005
V-Carve Pro 12.005
Exactly what I was looking for, I still not always clear on the fluting verses molding verses chamfer tool.
JOe
"I just selected the 30 radial lines and used the following parameters:"
JOe
